09-24 19:51:30:995 TX:opus
09-24 19:51:31:125 D/battery batt_gauge: Current status: Charging
09-24 19:51:31:126 I/audio tshell: switch to mic record
09-24 19:51:31:127 I/audio tshell: audio_open type=6 d=0 rw=2 tx cache=2048 rx cache=0
09-24 19:51:31:128 I/audio audiosvr: audio cmd=0
09-24 19:51:31:129 I/audio audiosvr: audio_client_start h=6007ce60 n=record t=6 f=2 d=0
09-24 19:51:31:130 I/audio audiosvr: audio_device_open in d=0 busy=0 reg=1 c=6007ce60
09-24 19:51:31:131 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:51:31:132 I/audio audiosvr: device 0 info end
09-24 19:51:31:132 I/audio audiosvr: server first stream
09-24 19:51:31:134 I/audio audiosvr: device 0 first stream
09-24 19:51:31:135 I/audio audiosvr: device count tx=0 rx=0 busy=0
09-24 19:51:31:136 I/audio audiosvr: hardware_device_open in: r=0 t=0 b=0 d=0 c=0x6007ce60 f=2
09-24 19:51:31:137 I/audio audiosvr: audio_device_speaker_open in r=0 t=0 c=0x6007ce60 f=2 mic=0 mic_ch=1 3a=0
09-24 19:51:31:137 I/audio audiosvr: need init tx=0 rx=1
09-24 19:51:31:138 I/audio audiosvr: (tx rx): ch[1,1] rate(16000 16000)
09-24 19:51:31:139 I/audio audiosvr: config_rx mic=0
09-24 19:51:31:139 I/audio audiosvr: non modem config rx–set callback
09-24 19:51:31:140 I/audio audiosvr: codec input parameter:sub_type=4 channels 1, rate 16000, bits 16
09-24 19:51:31:141 I/audio audiosvr: mic0: channels 1, type=0 rate 16000, bitwidth 16
09-24 19:51:31:142 get_mic_volume = 12db
09-24 19:51:31:143 I/audio audiosvr: start_rx need_adc_rx=1
09-24 19:51:31:144 acce, x: 49, y: 189, z: 999
09-24 19:51:31:145 gyro, x: 1050, y: -5390, z: -1330
09-24 19:51:31:146 lsm6d step, step: 0
09-24 19:51:31:147 I/drv.audcodec audiosvr: pll config state:1, samplerate:44100
09-24 19:51:31:171 get_mic_volume = 12db
09-24 19:51:31:172 I/audio audiosvr: audio_device_speaker_open out
09-24 19:51:31:173 I/audio audiosvr: hardware_device_open out: rx=1 tx=0 b=1
09-24 19:51:31:174 I/audio audiosvr: callback opened ok
09-24 19:51:31:175 I/audio audiosvr: audio_device_open out
09-24 19:51:31:176 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:51:31:177 I/audio audiosvr: running: d=0 h=6007ce60 name=record type=6 rw=2 device_s=0 device_u=0 prio=93
09-24 19:51:31:178 I/audio audiosvr: device 0 info end
09-24 19:51:31:179 I/audio audiosvr: audio_client_start out
09-24 19:51:32:729 I/audio tshell: audio_open ret=0x6007ce60
09-24 19:51:32:837 acce, x: 45, y: 188, z: 1005
09-24 19:51:32:838 gyro, x: 210, y: -4480, z: -1400
09-24 19:51:34:215 lsm6d step, step: 0
09-24 19:51:34:218 ch[7]voltage=41998;21013.32
09-24 19:51:34:693 D/battery batt_gauge: Current status: Charging
09-24 19:51:34:696 acce, x: 46, y: 190, z: 1004
09-24 19:51:34:697 gyro, x: 1400, y: -3920, z: -280
09-24 19:51:36:248 lsm6d step, step: 0
09-24 19:51:36:513 --audio pipe full
09-24 19:51:36:518 acce, x: 49, y: 190, z: 1003
09-24 19:51:36:518 gyro, x: 770, y: -2310, z: -350
09-24 19:51:38:062 lsm6d step, step: 0
09-24 19:51:38:341 acce, x: 47, y: 190, z: 1010
09-24 19:51:38:345 gyro, x: 2100, y: -9170, z: 700
09-24 19:51:38:897 lsm6d step, step: 0
09-24 19:51:38:899 ch[7]voltage=42001;21014.36
09-24 19:51:40:181 D/battery batt_gauge: Current status: Charging
09-24 19:51:40:184 acce, x: 33, y: 201, z: 1003
09-24 19:51:40:185 gyro, x: -1120, y: -6930, z: 70
09-24 19:51:41:731 lsm6d step, step: 0
09-24 19:51:41:978 acce, x: 30, y: 196, z: 1003
09-24 19:51:41:983 gyro, x: 700, y: -4270, z: -1190
09-24 19:51:42:242 lsm6d step, step: 0
09-24 19:51:42:245 I/NO_TAG timer: ============================
09-24 19:51:42:246 I/NO_TAG timer: CPU Usage: 8.56/ 13.22 ( 35.23%)
09-24 19:51:42:247 I/NO_TAG timer: ========================================================
09-24 19:51:42:248 I/NO_TAG timer: thread run_time(s) load(%)
09-24 19:51:42:248 I/NO_TAG timer: --------------------------------------------------------
09-24 19:51:42:249 I/NO_TAG timer: [mp3 ]: 0.00 0.00%
09-24 19:51:42:250 I/NO_TAG timer: [bts ]: 0.00 0.00%
09-24 19:51:42:251 I/NO_TAG timer: [KE_EVT3 ]: 0.00 0.00%
09-24 19:51:42:252 I/NO_TAG timer: [KE_EVT0 ]: 0.00 0.00%
09-24 19:51:42:252 I/NO_TAG timer: [KE_EVT2 ]: 0.00 0.00%
09-24 19:51:42:253 I/NO_TAG timer: [lcd_tas ]: 0.06 0.46%
09-24 19:51:42:254 I/NO_TAG timer: [mp3_pro ]: 0.00 0.00%
09-24 19:51:42:255 I/NO_TAG timer: [batt_ga ]: 0.02 0.16%
09-24 19:51:42:256 I/NO_TAG timer: [tshell ]: 0.13 0.95%
09-24 19:51:42:256 I/NO_TAG timer: [Mwath_t ]: 0.67 5.09%
09-24 19:51:42:257 I/NO_TAG timer: [sd_work ]: 0.00 0.00%
09-24 19:51:42:258 I/NO_TAG timer: [usbd_ms ]: 0.00 0.00%
09-24 19:51:42:258 I/NO_TAG timer: [deplayb ]: 0.00 0.00%
09-24 19:51:42:259 I/NO_TAG timer: [bt_down ]: 0.00 0.00%
09-24 19:51:42:259 I/NO_TAG timer: [audiosv ]: 3.74 28.27%
09-24 19:51:42:260 I/NO_TAG timer: [alarmsv ]: 0.00 0.00%
09-24 19:51:42:261 I/NO_TAG timer: [tcpip ]: 0.01 0.06%
09-24 19:51:42:261 I/NO_TAG timer: [etx ]: 0.00 0.00%
09-24 19:51:42:262 I/NO_TAG timer: [erx ]: 0.00 0.00%
09-24 19:51:42:264 I/NO_TAG timer: [tidle ]: 8.56 64.77%
09-24 19:51:42:265 I/NO_TAG timer: [timer ]: 0.02 0.12%
09-24 19:51:42:265 I/NO_TAG timer: [main ]: 0.02 0.13%
09-24 19:51:43:570 I/audio audiosvr: read error len=0
09-24 19:51:43:574 ch[7]voltage=42006;21016.96
09-24 19:51:43:801 D/battery batt_gauge: Current status: Charging
09-24 19:51:43:804 acce, x: 36, y: 195, z: 1001
09-24 19:51:43:805 gyro, x: 840, y: -6440, z: -490
09-24 19:51:45:115 lsm6d step, step: 0
09-24 19:51:45:117 I/audio tshell: audio_close type=6 n=record h=0x6007ce60
09-24 19:51:45:118 I/audio audiosvr: audio cmd=1
09-24 19:51:45:120 I/audio audiosvr: audio_client_stop 0x6007ce60 record pm_debug=0
09-24 19:51:45:121 I/audio audiosvr: callback closed ok
09-24 19:51:45:122 I/audio audiosvr: audio_device_close in d=0 busy=1 reg=1 c=6007ce60
09-24 19:51:45:122 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:51:45:123 I/audio audiosvr: running: d=0 h=6007ce60 name=record type=6 rw=2 device_s=0 device_u=0 prio=93
09-24 19:51:45:124 I/audio audiosvr: device 0 info end
09-24 19:51:45:125 I/audio audiosvr: device count tx=0 rx=1 busy=1
09-24 19:51:45:125 I/audio audiosvr: hardware_device_close in: d=0 r=1 t=0 b=1 f=2
09-24 19:51:45:126 I/audio audiosvr: audio_device_speaker_close in t=0 r=1 c=0x6007ce60 f=2
09-24 19:51:45:126 I/audio audiosvr: audio_device_speaker_close ref(t=0 r=0) deinit(t=0 r=1)
09-24 19:51:45:127 I/audio audiosvr: close rx
09-24 19:51:45:127 I/drv.audcodec audiosvr: bf0_audio_stop 0x401
09-24 19:51:45:128 I/drv.audcodec audiosvr: audcodec close adc
09-24 19:51:45:129 I/drv.audcodec audiosvr: bf0_audio_stop 0x401 done
09-24 19:51:45:130 I/drv.audprc audiosvr: bf0_audio_stop 0x1001
09-24 19:51:45:131 I/drv.audprc audiosvr: audprc close adc/dac
09-24 19:51:45:131 I/drv.audprc audiosvr: bf0_audio_stop 0x1001 done
09-24 19:51:45:132 I/audio audiosvr: close device & pll, micbias=0
09-24 19:51:45:133 PLL disable
09-24 19:51:45:133 I/audio audiosvr: audio_device_speaker_close out
09-24 19:51:45:134 I/audio audiosvr: hardware_device_close out: r=0 t=0 b=0
09-24 19:51:45:134 I/audio audiosvr: running some suspend
09-24 19:51:45:135 I/audio audiosvr: suspend empty
09-24 19:51:45:136 I/audio audiosvr: audio_device_close out
09-24 19:51:45:136 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:51:45:137 I/audio audiosvr: device 0 info end
09-24 19:51:45:137 I/audio audiosvr: audio_client_stop out pm=0
09-24 19:51:45:315 I/audio tshell: audio_close done
09-24 19:51:45:353 I/audio tshell: audio_open type=4 d=253 rw=1 tx cache=4096 rx cache=0
09-24 19:51:45:354 I/audio audiosvr: audio cmd=0
09-24 19:51:45:355 I/audio audiosvr: audio_client_start h=6007ce60 n=music t=4 f=1 d=253
09-24 19:51:45:356 I/audio audiosvr: audio_device_open in d=0 busy=0 reg=1 c=6007ce60
09-24 19:51:45:357 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:51:45:357 I/audio audiosvr: device 0 info end
09-24 19:51:45:359 I/audio audiosvr: server first stream
09-24 19:51:45:360 I/audio audiosvr: device 0 first stream
09-24 19:51:45:361 I/audio audiosvr: device count tx=0 rx=0 busy=0
09-24 19:51:45:362 I/audio audiosvr: hardware_device_open in: r=0 t=0 b=0 d=0 c=0x6007ce60 f=1
09-24 19:51:45:362 I/audio audiosvr: audio_device_speaker_open in r=0 t=0 c=0x6007ce60 f=1 mic=0 mic_ch=1 3a=0
09-24 19:51:45:363 I/audio audiosvr: need init tx=1 rx=0
09-24 19:51:45:364 I/drv.audprc audiosvr: set g_eq_enable=1
09-24 19:51:45:365 I/audio audiosvr: (tx rx): ch[1,1] rate(16000 16000)
09-24 19:51:45:366 I/audio audiosvr: set tx callback dma size=960 t=4
09-24 19:51:45:366 I/audio audiosvr: prc_codec : sub_type=1 channel 1, samplerate 16000, bits 16
09-24 19:51:45:367 I/audio audiosvr: speaker OUTPUTSRC channel=1 in_rate=16000 out_rate=16000
09-24 19:51:45:368 I/audio audiosvr: speaker select=0x5050 mixer=0x5050
09-24 19:51:45:369 I/audio audiosvr: tx[0]: sub_type 0, ch 1, samrate 16000, bits 16
09-24 19:51:45:371 I/audio audiosvr: no eq init volume=-20
09-24 19:51:45:372 I/drv.audcodec audiosvr: dac set volume: prc=0 codec=-20
09-24 19:51:45:372 I/drv.audcodec audiosvr: codec dac mute set:1
09-24 19:51:45:373 I/audio audiosvr: speaker START stream=0x100
09-24 19:51:45:374 I/drv.audprc audiosvr: samplerate = 16000, select voice eq
09-24 19:51:45:374 I/drv.audprc audiosvr: -----tx dma size = 960
09-24 19:51:45:375 I/audio audiosvr: codec START stream=0x100
09-24 19:51:45:376 I/drv.audcodec audiosvr: pll config state:1, samplerate:44100
09-24 19:51:45:377 I/audio audiosvr: open PA, unmute DAC
09-24 19:51:45:378 sifli_aw8155 to do power handle
09-24 19:51:45:438 sifli_aw8155_start,mode:2 11
09-24 19:51:45:440 I/drv.audcodec audiosvr: codec dac mute set:0
09-24 19:51:45:440 I/audio audiosvr: audio_device_speaker_open out
09-24 19:51:45:442 I/audio audiosvr: hardware_device_open out: rx=0 tx=1 b=1
09-24 19:51:45:442 I/audio audiosvr: callback opened ok
09-24 19:51:45:443 I/audio audiosvr: audio_device_open out
09-24 19:51:45:444 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:51:45:445 I/audio audiosvr: running: d=0 h=6007ce60 name=music type=4 rw=1 device_s=253 device_u=0 prio=10
09-24 19:51:45:446 I/audio audiosvr: device 0 info end
09-24 19:51:45:446 I/audio audiosvr: audio_client_start out
09-24 19:51:45:469 I/audio tshell: audio_open ret=0x6007ce60
09-24 19:51:45:471 I/audio ISR: not eq change volume=-20
09-24 19:51:45:638 I/drv.audcodec ISR: dac set volume: prc=0 codec=-20
09-24 19:51:45:641 acce, x: 34, y: 197, z: 1000
09-24 19:51:45:643 gyro, x: 840, y: -4550, z: -560
09-24 19:51:46:940 lsm6d step, step: 0
09-24 19:51:46:944 acce, x: 33, y: 218, z: 975
09-24 19:51:46:945 gyro, x: -11550, y: -12250, z: -3710
09-24 19:51:47:498 lsm6d step, step: 0
09-24 19:51:47:502 ch[7]voltage=41982;21005.02
09-24 19:51:48:243 D/battery batt_gauge: Current status: Charging
09-24 19:51:48:246 acce, x: 193, y: -669, z: 402
09-24 19:51:48:247 gyro, x: -3290, y: 4970, z: -10920
09-24 19:51:49:543 lsm6d step, step: 0
09-24 19:51:49:546 acce, x: 396, y: -812, z: 333
09-24 19:51:49:548 gyro, x: -3570, y: -6370, z: 12040
09-24 19:51:50:813 lsm6d step, step: 0
09-24 19:51:50:817 ch[7]voltage=41984;21006.05
09-24 19:51:50:844 D/battery batt_gauge: Current status: Charging
09-24 19:51:50:847 acce, x: 465, y: -853, z: 268
09-24 19:51:50:849 gyro, x: 4550, y: -5530, z: 0
09-24 19:51:52:143 lsm6d step, step: 0
09-24 19:51:52:147 acce, x: 523, y: -819, z: 292
09-24 19:51:52:148 gyro, x: 2940, y: -5390, z: -910
09-24 19:51:53:209 lsm6d step, step: 0
09-24 19:51:53:211 I/NO_TAG timer: ============================
09-24 19:51:53:212 I/NO_TAG timer: CPU Usage: 8.94/ 10.98 ( 18.51%)
09-24 19:51:53:214 I/NO_TAG timer: ========================================================
09-24 19:51:53:215 I/NO_TAG timer: thread run_time(s) load(%)
09-24 19:51:53:215 I/NO_TAG timer: --------------------------------------------------------
09-24 19:51:53:216 I/NO_TAG timer: [mp3 ]: 0.00 0.00%
09-24 19:51:53:216 I/NO_TAG timer: [bts ]: 0.00 0.00%
09-24 19:51:53:217 I/NO_TAG timer: [KE_EVT3 ]: 0.00 0.00%
09-24 19:51:53:218 I/NO_TAG timer: [KE_EVT0 ]: 0.00 0.00%
09-24 19:51:53:219 I/NO_TAG timer: [KE_EVT2 ]: 0.00 0.00%
09-24 19:51:53:219 I/NO_TAG timer: [lcd_tas ]: 0.06 0.53%
09-24 19:51:53:221 I/NO_TAG timer: [mp3_pro ]: 0.00 0.00%
09-24 19:51:53:222 I/NO_TAG timer: [batt_ga ]: 0.02 0.19%
09-24 19:51:53:222 I/NO_TAG timer: [tshell ]: 0.18 1.67%
09-24 19:51:53:223 I/NO_TAG timer: [Mwath_t ]: 0.67 6.14%
09-24 19:51:53:224 I/NO_TAG timer: [sd_work ]: 0.00 0.00%
09-24 19:51:53:224 I/NO_TAG timer: [usbd_ms ]: 0.00 0.00%
09-24 19:51:53:226 I/NO_TAG timer: [deplayb ]: 0.00 0.00%
09-24 19:51:53:226 I/NO_TAG timer: [bt_down ]: 0.00 0.00%
09-24 19:51:53:227 I/NO_TAG timer: [audiosv ]: 1.06 9.63%
09-24 19:51:53:228 I/NO_TAG timer: [alarmsv ]: 0.00 0.00%
09-24 19:51:53:229 I/NO_TAG timer: [tcpip ]: 0.01 0.07%
09-24 19:51:53:230 I/NO_TAG timer: [etx ]: 0.00 0.00%
09-24 19:51:53:231 I/NO_TAG timer: [erx ]: 0.00 0.00%
09-24 19:51:53:232 I/NO_TAG timer: [tidle ]: 8.94 81.49%
09-24 19:51:53:233 I/NO_TAG timer: [timer ]: 0.02 0.14%
09-24 19:51:53:441 I/NO_TAG timer: [main ]: 0.02 0.14%
09-24 19:51:53:448 acce, x: 498, y: -828, z: 341
09-24 19:51:53:449 gyro, x: 1890, y: 2030, z: -280
09-24 19:51:54:125 lsm6d step, step: 0
09-24 19:51:54:128 ch[7]voltage=41986;21007.09
09-24 19:51:54:743 D/battery batt_gauge: Current status: Charging
09-24 19:51:54:747 acce, x: 500, y: -820, z: 334
09-24 19:51:54:747 gyro, x: -6370, y: -3990, z: 1820
09-24 19:51:55:425 lsm6d step, step: 0
09-24 19:51:55:429 I/audio tshell: audio_close type=4 n=music h=0x6007ce60
09-24 19:51:55:430 I/audio audiosvr: audio cmd=1
09-24 19:51:55:431 I/audio audiosvr: audio_client_stop 0x6007ce60 music pm_debug=0
09-24 19:51:55:432 I/audio audiosvr: callback closed ok
09-24 19:51:55:433 I/audio audiosvr: audio_device_close in d=0 busy=1 reg=1 c=6007ce60
09-24 19:51:55:433 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:51:55:433 I/audio audiosvr: running: d=0 h=6007ce60 name=music type=4 rw=1 device_s=253 device_u=0 prio=10
09-24 19:51:55:434 I/audio audiosvr: device 0 info end
09-24 19:51:55:435 I/audio audiosvr: device count tx=1 rx=0 busy=1
09-24 19:51:55:436 I/audio audiosvr: hardware_device_close in: d=0 r=0 t=1 b=1 f=1
09-24 19:51:55:438 I/audio audiosvr: audio_device_speaker_close in t=1 r=0 c=0x6007ce60 f=1
09-24 19:51:55:439 I/audio audiosvr: audio_device_speaker_close ref(t=0 r=0) deinit(t=1 r=0)
09-24 19:51:55:440 I/audio audiosvr: close tx & pa
09-24 19:51:55:441 sifli_aw8155_stop
09-24 19:51:55:442 I/drv.audcodec audiosvr: codec dac mute set:1
09-24 19:51:55:444 I/drv.audcodec audiosvr: bf0_audio_stop 0x100
09-24 19:51:55:445 I/drv.audcodec audiosvr: audcodec close dac
09-24 19:51:55:446 I/drv.audcodec audiosvr: bf0_audio_stop 0x100 done
09-24 19:51:55:447 I/drv.audprc audiosvr: bf0_audio_stop 0x100
09-24 19:51:55:447 I/drv.audprc audiosvr: audprc close adc/dac
09-24 19:51:55:448 I/drv.audprc audiosvr: bf0_audio_stop 0x100 done
09-24 19:51:55:449 I/audio audiosvr: close device & pll, micbias=0
09-24 19:51:55:450 PLL disable
09-24 19:51:55:450 I/audio audiosvr: audio_device_speaker_close out
09-24 19:51:55:451 I/audio audiosvr: hardware_device_close out: r=0 t=0 b=0
09-24 19:51:55:452 I/audio audiosvr: running some suspend
09-24 19:51:55:453 I/audio audiosvr: suspend empty
09-24 19:51:55:455 I/audio audiosvr: audio_device_close out
09-24 19:51:55:456 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:51:55:456 I/audio audiosvr: device 0 info end
09-24 19:51:55:457 I/audio audiosvr: audio_client_stop out pm=0
09-24 19:51:55:458 I/audio tshell: audio_close done
09-24 19:51:55:458 opus runing stack var address =0x2004c854
09-24 19:51:55:459 opus alloc=24544 0x6007ce60
09-24 19:51:55:459 encoder create=0
09-24 19:51:55:460 opus alloc=17776 0x60082e68
09-24 19:51:55:461 decoder create=0
09-24 19:51:55:461 I/audio opus: audio_open type=6 d=253 rw=3 tx cache=2560 rx cache=0
09-24 19:51:55:462 I/audio audiosvr: audio cmd=0
09-24 19:51:55:463 I/audio audiosvr: audio_client_start h=60087400 n=record t=6 f=3 d=253
09-24 19:51:55:463 I/audio audiosvr: notify listern(0, 0)
09-24 19:51:55:464 I/audio audiosvr: audio_device_open in d=0 busy=0 reg=1 c=60087400
09-24 19:51:55:464 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:51:55:465 I/audio audiosvr: device 0 info end
09-24 19:51:55:466 I/audio audiosvr: server first stream
09-24 19:51:55:467 I/audio audiosvr: device 0 first stream
09-24 19:51:55:467 I/audio audiosvr: device count tx=0 rx=0 busy=0
09-24 19:51:55:468 I/audio audiosvr: hardware_device_open in: r=0 t=0 b=0 d=0 c=0x60087400 f=3
09-24 19:51:55:469 I/audio audiosvr: audio_device_speaker_open in r=0 t=0 c=0x60087400 f=3 mic=0 mic_ch=1 3a=0
09-24 19:51:55:470 I/audio audiosvr: need init tx=1 rx=1
09-24 19:51:55:470 I/drv.audprc audiosvr: set g_eq_enable=1
09-24 19:51:55:472 I/audio audiosvr: (tx rx): ch[1,1] rate(16000 16000)
09-24 19:51:55:472 I/audio audiosvr: set tx callback dma size=960 t=6
09-24 19:51:55:473 I/audio audiosvr: prc_codec : sub_type=1 channel 1, samplerate 16000, bits 16
09-24 19:51:55:473 I/audio audiosvr: speaker OUTPUTSRC channel=1 in_rate=16000 out_rate=16000
09-24 19:51:55:474 I/audio audiosvr: speaker select=0x5050 mixer=0x5050
09-24 19:51:55:475 I/audio audiosvr: tx[0]: sub_type 0, ch 1, samrate 16000, bits 16
09-24 19:51:55:475 I/audio audiosvr: no eq init volume=-20
09-24 19:51:55:476 I/drv.audcodec audiosvr: dac set volume: prc=0 codec=-20
09-24 19:51:55:477 I/audio audiosvr: config_rx mic=0
09-24 19:51:55:477 I/audio audiosvr: non modem config rx–set callback
09-24 19:51:55:478 I/audio audiosvr: codec input parameter:sub_type=4 channels 1, rate 16000, bits 16
09-24 19:51:55:479 I/audio audiosvr: mic0: channels 1, type=0 rate 16000, bitwidth 16
09-24 19:51:55:480 get_mic_volume = 12db
09-24 19:51:55:481 get_mic_volume = 12db
09-24 19:51:55:481 I/drv.audcodec audiosvr: codec dac mute set:1
09-24 19:51:55:482 I/audio audiosvr: speaker START stream=0x100
09-24 19:51:55:482 I/drv.audprc audiosvr: samplerate = 16000, select voice eq
09-24 19:51:55:483 I/drv.audprc audiosvr: -----tx dma size = 960
09-24 19:51:55:484 I/audio audiosvr: codec START stream=0x100
09-24 19:51:55:484 I/drv.audcodec audiosvr: pll config state:1, samplerate:44100
09-24 19:51:55:485 I/audio audiosvr: wait rx start
09-24 19:51:55:503 msh />msh />I/audio ISR: start_rx need_adc_rx=1
09-24 19:51:55:505 I/drv.audcodec ISR: pll config state:1, samplerate:44100
09-24 19:51:55:533 get_mic_volume = 12db
09-24 19:51:55:536 I/audio audiosvr: got rx start 0
09-24 19:51:55:536 I/audio audiosvr: open PA, unmute DAC
09-24 19:51:55:537 sifli_aw8155 to do power handle
09-24 19:51:55:627 sifli_aw8155_start,mode:2 11
09-24 19:51:55:655 I/drv.audcodec audiosvr: codec dac mute set:0
09-24 19:51:55:656 I/audio audiosvr: audio_device_speaker_open out
09-24 19:51:55:658 I/audio audiosvr: hardware_device_open out: rx=1 tx=1 b=1
09-24 19:51:55:660 I/audio audiosvr: audio_device_open out
09-24 19:51:55:660 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:51:55:661 I/audio audiosvr: running: d=0 h=60087400 name=record type=6 rw=3 device_s=253 device_u=0 prio=93
09-24 19:51:55:662 I/audio audiosvr: device 0 info end
09-24 19:51:55:662 I/audio audiosvr: audio_client_start out
09-24 19:51:55:663 I/audio opus: audio_open ret=0x60087400
09-24 19:51:55:664 I/audio ISR: not eq change volume=-20
09-24 19:51:56:062 I/drv.audcodec ISR: dac set volume: prc=0 codec=-20
09-24 19:51:56:065 acce, x: 517, y: -810, z: 302
09-24 19:51:56:066 gyro, x: -2450, y: -2310, z: -70
09-24 19:51:57:357 lsm6d step, step: 0
09-24 19:51:57:361 acce, x: 559, y: -791, z: 308
09-24 19:51:57:361 gyro, x: -280, y: -5880, z: 4480
09-24 19:51:57:482 lsm6d step, step: 0
09-24 19:51:57:485 ch[7]voltage=41980;21003.98
09-24 19:51:58:663 D/battery batt_gauge: Current status: Charging
09-24 19:51:58:664 acce, x: 520, y: -816, z: 317
09-24 19:51:58:665 gyro, x: 3360, y: -4480, z: -7210
09-24 19:51:59:967 lsm6d step, step: 0
09-24 19:51:59:970 acce, x: 517, y: -811, z: 312
09-24 19:51:59:971 gyro, x: 3990, y: -3290, z: 1750
09-24 19:52:00:809 lsm6d step, step: 0
09-24 19:52:00:810 ch[7]voltage=41970;20999.31
09-24 19:52:01:260 D/battery batt_gauge: Current status: Charging
09-24 19:52:01:263 acce, x: 456, y: -818, z: 322
09-24 19:52:01:264 gyro, x: 1820, y: -3220, z: 8470
09-24 19:52:02:570 lsm6d step, step: 0
09-24 19:52:02:573 acce, x: 447, y: -822, z: 410
09-24 19:52:02:574 gyro, x: 11550, y: -7770, z: -560
09-24 19:52:03:241 lsm6d step, step: 0
09-24 19:52:03:242 I/NO_TAG timer: ============================
09-24 19:52:03:243 I/NO_TAG timer: CPU Usage: 6.26/ 10.02 ( 37.46%)
09-24 19:52:03:244 I/NO_TAG timer: ========================================================
09-24 19:52:03:245 I/NO_TAG timer: thread run_time(s) load(%)
09-24 19:52:03:245 I/NO_TAG timer: --------------------------------------------------------
09-24 19:52:03:246 I/NO_TAG timer: [opus ]: 2.74 27.37%
09-24 19:52:03:247 I/NO_TAG timer: [mp3 ]: 0.00 0.00%
09-24 19:52:03:247 I/NO_TAG timer: [bts ]: 0.00 0.00%
09-24 19:52:03:248 I/NO_TAG timer: [KE_EVT3 ]: 0.00 0.00%
09-24 19:52:03:249 I/NO_TAG timer: [KE_EVT0 ]: 0.00 0.00%
09-24 19:52:03:250 I/NO_TAG timer: [KE_EVT2 ]: 0.00 0.00%
09-24 19:52:03:250 I/NO_TAG timer: [lcd_tas ]: 0.08 0.83%
09-24 19:52:03:251 I/NO_TAG timer: [mp3_pro ]: 0.00 0.00%
09-24 19:52:03:252 I/NO_TAG timer: [batt_ga ]: 0.02 0.21%
09-24 19:52:03:252 I/NO_TAG timer: [tshell ]: 0.00 0.02%
09-24 19:52:03:253 I/NO_TAG timer: [Mwath_t ]: 0.75 7.45%
09-24 19:52:03:254 I/NO_TAG timer: [sd_work ]: 0.00 0.00%
09-24 19:52:03:254 I/NO_TAG timer: [usbd_ms ]: 0.00 0.00%
09-24 19:52:03:255 I/NO_TAG timer: [deplayb ]: 0.00 0.00%
09-24 19:52:03:256 I/NO_TAG timer: [bt_down ]: 0.00 0.00%
09-24 19:52:03:257 I/NO_TAG timer: [audiosv ]: 0.11 1.09%
09-24 19:52:03:257 I/NO_TAG timer: [alarmsv ]: 0.00 0.00%
09-24 19:52:03:259 I/NO_TAG timer: [tcpip ]: 0.01 0.13%
09-24 19:52:03:260 I/NO_TAG timer: [etx ]: 0.00 0.00%
09-24 19:52:03:260 I/NO_TAG timer: [erx ]: 0.00 0.00%
09-24 19:52:03:261 I/NO_TAG timer: [tidle ]: 6.26 62.54%
09-24 19:52:03:262 I/NO_TAG timer: [timer ]: 0.02 0.15%
09-24 19:52:03:263 I/NO_TAG timer: [main ]: 0.02 0.19%
09-24 19:52:03:861 I/audio audiosvr: read error len=0
09-24 19:52:03:863 acce, x: 504, y: -798, z: 360
09-24 19:52:03:864 gyro, x: 8330, y: -3430, z: -2590
09-24 19:52:04:139 lsm6d step, step: 0
09-24 19:52:04:142 ch[7]voltage=41977;21002.42
09-24 19:52:05:159 D/battery batt_gauge: Current status: Charging
09-24 19:52:05:162 acce, x: 557, y: -791, z: 421
09-24 19:52:05:163 gyro, x: -2450, y: -3780, z: -1050
09-24 19:52:05:982 lsm6d step, step: 0
09-24 19:52:05:985 I/audio opus: audio_close type=6 n=record h=0x60087400
09-24 19:52:05:986 I/audio audiosvr: audio cmd=1
09-24 19:52:05:987 I/audio audiosvr: audio_client_stop 0x60087400 record pm_debug=0
09-24 19:52:05:988 I/audio audiosvr: audio_device_close in d=0 busy=1 reg=1 c=60087400
09-24 19:52:05:989 I/audio audiosvr: device 0 info reg=1 busy=1:
09-24 19:52:05:990 I/audio audiosvr: running: d=0 h=60087400 name=record type=6 rw=3 device_s=253 device_u=0 prio=93
09-24 19:52:05:991 I/audio audiosvr: device 0 info end
09-24 19:52:05:991 I/audio audiosvr: device count tx=1 rx=1 busy=1
09-24 19:52:05:992 I/audio audiosvr: hardware_device_close in: d=0 r=1 t=1 b=1 f=3
09-24 19:52:05:993 I/audio audiosvr: audio_device_speaker_close in t=1 r=1 c=0x60087400 f=3
09-24 19:52:05:993 I/audio audiosvr: audio_device_speaker_close ref(t=0 r=0) deinit(t=1 r=1)
09-24 19:52:05:994 I/audio audiosvr: close pa txrx
09-24 19:52:05:995 sifli_aw8155_stop
09-24 19:52:05:996 I/drv.audcodec audiosvr: codec dac mute set:1
09-24 19:52:05:997 I/drv.audcodec audiosvr: bf0_audio_stop 0x502
09-24 19:52:05:998 I/drv.audcodec audiosvr: audcodec close dac
09-24 19:52:05:999 I/drv.audcodec audiosvr: audcodec close adc
09-24 19:52:06:000 I/drv.audcodec audiosvr: bf0_audio_stop 0x502 done
09-24 19:52:06:000 I/drv.audprc audiosvr: bf0_audio_stop 0x1102
09-24 19:52:06:001 I/drv.audprc audiosvr: audprc close adc/dac
09-24 19:52:06:002 I/drv.audprc audiosvr: bf0_audio_stop 0x1102 done
09-24 19:52:06:003 I/audio audiosvr: close device & pll, micbias=0
09-24 19:52:06:004 PLL disable
09-24 19:52:06:004 I/audio audiosvr: audio_device_speaker_close out
09-24 19:52:06:005 I/audio audiosvr: hardware_device_close out: r=0 t=0 b=0
09-24 19:52:06:006 I/audio audiosvr: running some suspend
09-24 19:52:06:006 I/audio audiosvr: suspend empty
09-24 19:52:06:007 I/audio audiosvr: audio_device_close out
09-24 19:52:06:007 I/audio audiosvr: device 0 info reg=1 busy=0:
09-24 19:52:06:008 I/audio audiosvr: device 0 info end
09-24 19:52:06:009 I/audio audiosvr: audio_client_stop out pm=0
09-24 19:52:06:009 I/audio opus: audio_close done
09-24 19:52:06:461 —opus test exit—
好像录制不了音频,请帮忙分析一下原因
