System setting: shutdown below 3.48V. When the battery voltage is between 3.3V and 3.2V, connecting the charger causes the microcontroller to freeze. The measured current at power-on reaches over 600mA, likely because the display screen draws excessive current during startup. The external charging uses the same Huangshan Pai charging management solution, with charging management path AW32001. According to the datasheet, this chip’s default maximum charging current is 500mA, which leads to the MCU freezing. Without changing the hardware, is there a way to solve this?
If the load is insufficient and the current does not meet requirements, the system crashes before user program configuration, so software cannot be configured. The only solution is to modify the hardware so that the screen is disabled by default.
