- Loaded runtime config … OK
- Loaded profile lock ‘default’ … OK
│ Activating SiFli-SDK v2.5.1 │
│ profile=default │
└─────────────────────────────┘ - Resolved tool plan … OK
- Checking environment compatibility … OK
[ OK ] Updated state file C:\Users\EDY.sifli\sifli-sdk-env.json - Identified shell … powershell
- Generating shell export script … OK
- Export script … C:\Users\EDY\AppData\Local\Temp\sifli-sdk-export\sdk-env-0fga1x5u.ps1
Done! SiFli-SDK profile default is active.
You can now run sdk.py from your project directory.
PS D:\SiFi_Watch\V9_DEMO> cd .\sf32\qz_watch\project
PS D:\SiFi_Watch\V9_DEMO\sf32\qz_watch\project> scons --board=sf32lb52-lchspi-ulp -j8
scons: Reading SConscript files …
Board: sf32lb52-lchspi-ulp_hcpu
warning: the default selection ROTATE_MEM_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:24, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:23) of (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:18) is not contained in the choice
warning: the choice symbol ROTATE_MEM_IN_PSRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:21, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:20) is defined with a prompt outside the choice
warning: the choice symbol ROTATE_MEM_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:24, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:23) is defined with a prompt outside the choice
warning: the default selection FREETYPE_CACHE_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:38, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:36) of (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:30) is not contained in the choice
warning: the choice symbol FREETYPE_CACHE_IN_PSRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:33, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:31) is defined with a prompt outside the choice
warning: the choice symbol FREETYPE_CACHE_IN_SRAM_STANDALONE (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:36, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:34) is defined with a prompt outside the choice
warning: the choice symbol FREETYPE_CACHE_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:38, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:36) is defined with a prompt outside the choice
warning: the default selection MESSAGE_CACHE_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:58, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:49) of (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:50) is not contained in the choice
warning: the choice symbol MESSAGE_CACHE_IN_PSRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:53, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:44) is defined with a prompt outside the choice
warning: the choice symbol MESSAGE_CACHE_IN_SRAM_STANDALONE (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:56, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:47) is defined with a prompt outside the choice
warning: the choice symbol MESSAGE_CACHE_IN_SRAM (defined at D:\SiFli-sdk\sifli-sdk/middleware/lvgl/Kconfig_mem:58, D:/SiFi_Watch/V9_DEMO/sf32/qz_watch/project/Kconfig.proj:49) is defined with a prompt outside the choice
error: Aborting due to Kconfig warnings
AssertionError: Fail to generate .config and rtconfig.h:
File “D:\SiFi_Watch\V9_DEMO\sf32\qz_watch\project\SConstruct”, line 12:
PrepareEnv()
File “D:\SiFli-sdk\sifli-sdk\tools\build\building.py”, line 4616:
InitBuild(None, rtconfig.OUTPUT_DIR, board)
File “D:\SiFli-sdk\sifli-sdk\tools\build\building.py”, line 3199:
ResolveBoardConfig(bsp_root, build_dir, board)
File “D:\SiFli-sdk\sifli-sdk\tools\build\building.py”, line 3190:
assert retcode == 0, “Fail to generate .config and rtconfig.h”
Activating SIFLI_SDK 2.4
Setting SIFLI_SDK_PATH to ‘D:\OpenSiFli\sifli-sdk’.
- Checking python version … 3.10.4
- Checking python dependencies … OK
- Deactivating the current SiFli-SDK environment (if any) … OK
- Establishing a new SiFli-SDK environment … OK
- Identifying shell … powershell.exe
- Detecting outdated tools in system … Found tools that are not used by active SiFli-SDK version.
For removing old versions of ninja, sftool use command ‘python.exe D:\OpenSiFli\sifli-sdk\tools\sifli_sdk_tools.py uninstall’
To free up even more space, remove installation packages of those tools.
Use option python.exe D:\OpenSiFli\sifli-sdk\tools\sifli_sdk_tools.py uninstall --remove-archives.
Done! You can now compile SiFli-SDK projects.
Go to the project directory and run:
两个编译相同的工程, 2.5的sdk 就直接报错。 能否给于帮助
