SF32LB56 issue
What is the default output of HVSW2 for SF30147C? It’s not specified in the datasheet. Also, if I don’t use VDDIO2 from HPSYS, can I leave GPIO Power unconnected?
I see, HVSW2 directly outputs the VBAT voltage.
VDDIO2 is used to power the IO and must be energized.
