📡 已连接到 COM20,波特率 1000000
📝 输入数据发送到设备。按 Ctrl+C 断开连接。
[18557] I/drv.lcd lcd_task: Found lcd yyh_480272 id:8000h
[18580] I/drv.lcd lcd_task: HW open done.
[18598] I/drv.lcd lcd_task: [OPENING] -> [INITIALIZED]
[18620] I/drv.lcd lcd_task: open done.
Warning: framebuffer color depth(24) mismatch! (Should match with LV_COLOR_DEPTH)
[18670] I/drv.lcd_fb main: drv_lcd_fb_init
[18689] I/drv.lcd_fb main: drv_lcd_fb_init done.
[18775] I/TOUCH main: Open
[18788] I/TOUCH tp_init: Find touch screen driver...
[18810] I/TOUCH tp_init: Probe 10007b15
[18827] I/drv.gt911 tp_init: probe OK
[18843] I/TOUCH tp_init: touch screen found driver 0x20024d78, gt911
[18872] I/TOUCH main: Opened.
[18886] I/LVGL main: [littlevgl2rtt] Welcome to the littlevgl2rtt lib.
Before custom_init
Custom init completed.
Before setup_ui
[Warn] (0.565, +565) file_decoder_info: Src type is wrong: 0
(in lvsf_img_decoder.c line #185)
[Warn] (0.566, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.570, +4) file_decoder_info: Src type is wrong: 0
[Warn] (0.571, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.573, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.574, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.576, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.577, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.579, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.580, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.582, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.583, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.585, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.586, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.588, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.589, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.598, +9) file_decoder_info: Src type is wrong: 0
[Warn] (0.599, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[21154] I/drv.gt911 tp_init: Firmware version = 0x1060(4192)
[Warn] (0.604, +5) file_decoder_info: Src type is wrong: 0
[Warn] (0.605, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.607, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.608, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.610, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.611, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.613, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.614, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.616, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.617, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.619, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.620, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.622, +2) file_decoder_info: Src type is wrong: 0
[Warn] (0.623, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.633, +10) file_decoder_info: Src type is wrong: 0
[Warn] (0.634, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.637, +3) file_decoder_info: Src type is wrong: 0
[Warn] (0.639, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.640, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.642, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.643, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.645, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.646, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.648, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.649, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.651, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.652, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.654, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.655, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.657, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.659, +2) file_decoder_info: Src type is wrong: 2
[Warn] (0.660, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.662, +2) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
[Warn] (0.663, +1) file_decoder_info: Src type is wrong: 2
[Warn] (0.664, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.665, +1) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
[Warn] (0.667, +2) file_decoder_info: Src type is wrong: 2
[Warn] (0.668, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.669, +1) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
[Warn] (0.671, +2) file_decoder_info: Src type is wrong: 2
[Warn] (0.672, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.673, +1) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
[Warn] (0.676, +3) file_decoder_info: Src type is wrong: 2
[Warn] (0.677, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.678, +1) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
[Warn] (0.680, +2) file_decoder_info: Src type is wrong: 2
[Warn] (0.681, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.682, +1) epic_cf_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #56)
UI setup completed.
Before events_init
Events init completed.
Entering main loop
[Warn] (0.688, +6) file_decoder_info: Src type is wrong: 0
[Warn] (0.690, +2) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[Warn] (0.691, +1) file_decoder_info: Src type is wrong: 0
[Warn] (0.692, +1) file_decoder_info: Image get info found unknown src type (in lvsf_img_decoder.c line #191)
[24144] E/drv.sdio mmcsd_de: wait 0 completed timeout 0x00000000,arg 0x00000000
clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 23 width 0
sp: 0x2002bd00
psr: 0x61000000
r00: 0x2002bcd0
r01: 0x0000002d
r02: 0x00000366
r03: 0x00000001
r04: 0xffffffff
r05: 0xffffffff
r06: 0xffffffff
r07: 0xffffffff
r08: 0xffffffff
r09: 0xffffffff
r10: 0xffffffff
r11: 0xffffffff
r12: 0x0000002e
lr: 0x10031779
pc: 0xfffffffe
hard fault on thread: main
PSP: 0x0x2002bc6c, MSP: 0x0x20001fc4
Thread Info
pri status sp top stack size max used left tick error
tpread 10 suspend 0x200232b0 0x200233bc 0x00000400 26% 0x0000000a 000
lcd_task 12 suspend 0x20022e58 0x20022fbc 0x00000800 41% 0x00000006 000
tshell 20 suspend 0x2002e050 0x2002e1cc 0x00001000 16% 0x0000000a 000
mmcsd_de 22 suspend 0x20023dd8 0x20023fbc 0x00000800 46% 0x00000011 000
tidle 31 ready 0x2000b008 0x2000b05c 0x00000200 18% 0x00000002 000
timer 4 suspend 0x20023768 0x200237bc 0x00000400 08% 0x00000009 000
main 19 ready 0x2002bc68 0x2002c3a0 0x00001000 89% 0x00000014 000
Mailbox Info
entry size suspend thread
mmcsdhot 0000 0004 0
mmcsdmb 0000 0004 0
MessageQueue Info
entry suspend thread
drv_lcd 0000 1:lcd_task�
Mutex Info
owner hold suspend thread
tplck (null) 0000 0
sdio mmcsd_de 0001 0
sd_bus_l mmcsd_de 0001 0
rtc (null) 0000 0
ulog loc (null) 0000 0
fslock (null) 0000 0
i2c_bus_ (null) 0000 0
Semaphore Info
v suspend thread
lv_data 001 0
tp_ctrl 001 0
lv_lcd 001 0
lcd_msg 000 0
lcd_draw 000 0
drv_lcd 001 0
shrx 000 0
epic 001 0
gt911 000 1:tpread
sd_ack 000 0
aes_drv 001 0
drv_eDma 001 0
nandlock 001 0
i2c1 000 0
heap 001 0
Memory Info
total memory: 563164 used memory : 54620 maximum allocated memory: 58436
MemoryHeap Info
pool size max used size available size
FPU active!
mem manage fault:
SCB_CFSR_MFSR:0x01 IACCVIOL
使用SDK2.4.5跑LVGL运行直接卡死,但是同样的代码切换成2.4.4/2.4.2就能行,请问大概是什么原因呢?
