In addition to the above IOs with device connections, qspi and iic are connected to a six-axis accelerometer with a maximum current of 20uA. All other IO pins are configured as input pull-down mode, and all other peripheral devices have been removed. During sleep, the following configuration is applied: the qspi pins are controlled accordingly, but the current still cannot be reduced to below 50uA.
ble_gap_scan_stop();
HAL_LPAON_Sleep();
rt_pm_run_enter(PM_RUN_MODE_MEDIUM_SPEED);
HAL_RAM_RET_CODE_SECT(BSP_PowerDownCustom, void BSP_PowerDownCustom(int coreid, bool is_deep_sleep))
#ifdef BSP_USING_NOR_FLASH2
HAL_PIN_Set(PAD_PA16, MPI2_CLK, PIN_NOPULL, 1);
HAL_PIN_Set(PAD_PA12, MPI2_CS, PIN_NOPULL, 1);
HAL_PIN_Set(PAD_PA15, MPI2_DIO0, PIN_PULLDOWN, 1);
HAL_PIN_Set(PAD_PA13, MPI2_DIO1, PIN_PULLDOWN, 1);
HAL_PIN_Set(PAD_PA14, MPI2_DIO2, PIN_PULLUP, 1);
HAL_PIN_Set(PAD_PA17, MPI2_DIO3, PIN_PULLUP, 1);
The serial port print during sleep is: [pm]S:3,127713
The current waveform is as follows: It feels like some component is still running. The original board peripherals should include iic, spi, lvgl, and an amoled screen. The lvgl tasks have all been disabled, and the spi and amoled screen interface components have also been completely removed.
