Connected to COM11 @ 1000000 baud
Type data to send to device. Press Ctrl+C to disconnect.
Serial:c2,Chip:4,Package:3,Rev:3 Reason:00000000
Serial PowerOnMOde:4 rtc_record:00000000
aw32001_init ok, time consum: 0.00 ms.
Charging current set successfully: 0.5c
Charging voltage set successfully
mount /dev sucess
[BUS]spi1 probe sdcard…
[MSD] 18 [info] SD card goto IDLE mode OK!
[MSD] 19 [info] CMD8 response : 0x01 0x00 0x00 0x01 0xAA
[MSD] 20 [info] Ver2.00 or later or SDHC or SDXC memory card!
[MSD] 20 SD_V2: READ_OCR
[MSD] 21 response:1,0,ff,80
[MSD] 22 [info] OCR is 0x00FF8000
[MSD] 42 SD_V2 again: READ_OCR
[MSD] 42 [info] OCR 2nd read is 0xC0FF8000
[MSD] 43 [info] It is SD2.0 SDHC Card!!!
[MSD] 45 [info] CSD Version 2.0
[MSD] 45 [info] CSD : C_SIZE : 59635
[MSD] 46 [info] card capacity : 29.11 Gbyte
[MSD] 46 [info] sector_count : 61067264
[MSD] 47 [info] TRAN_SPEED=0x32 → card_cap_hz=25000000 Hz
[SD]msd init ok
find sd0 ok ! 0x20046418
[I/FAL] Flash Abstraction Layer (V0.5.99) initialize success.
[I/FAL] The FAL MTD NOR device (dfu) created successfully
[I/FAL] The FAL MTD NOR device (ble) created successfully
[I/FAL] The FAL MTD NOR device (sensor) created successfully
[824] I/drv.rtc main: PSCLR=0x80000100 DivAI=128 DivAF=0 B=256
[832] I/drv.rtc main: RC10K Freq=9kHz, cycle=1009646, rtc ppm=0[839] I/drv.rtc main: DIVA=37, DIVA_FRA=2322, DIVB=256
[846] I/drv.rtc main: Init RTC, wake = 1
[853] I/drv.audprc main: init 00 ADC_PATH_CFG0 0x606
[859] I/drv.audprc main: HAL_AUDPRC_Init res 0
[865] I/drv.audcodec main: HAL_AUDCODEC_Init res 0
[872] I/TOUCH main: Regist touch screen driver, probe=0x12028409
lvsf_font_load: faces 1 ft_cache_size 300000
call par CFG1(3313)
fc 9, xtal 2000, pll 2099
call par CFG1(3313)
fc 7, xtal 2000, pll 1685
[SD] Hotplug init (IRQ mode)
[SD] Disk: root, capacity=29818 MB
[SD] Hotplug thread started (IRQ mode)
[SD] Mount / success
[SD] IRQ enabled on pin 27
Find i2c bus device i2c3
MMC56x3 ID = 0x10
[1165] I/drv.rtc app_watc: Get initial cycles: 1009646 rtc=1656633600.0000[1316] I/drv.rtc app_watc: Get initial cycles: 1009646 rtc=1656666000.0000
[1328] I/drv.lcd app_watc: [NONE] → [OPENING]
[1334] I/drv.lcd lcd_task: open
[1339] I/drv.epic lcd_task: drv_gpu opened.
[1344] I/drv.lcd lcd_task: HW open
[1354] I/drv.lcd lcd_task: Try registered LCD driver…
[1362] I/sensor main: rt_sensor init success
[1367] I/drv main: mag sensor init success
LSM6DS3TR ID = 0x6A
msh />[1569] I/sensor main: rt_sensor init success
[1575] I/drv main: acc sensor init success
[1580] I/sensor main: rt_sensor init success
[1585] I/drv main: gyro sensor init success
[1605] I/sibles ble_thre: enable BLE Core. Lib ver: bt.2.0.3d9c07bf
[1632] D/nvds mbox: NVDS Update Addr res 6, addr 21-09-80-52-fd-5c
[1642] I/nvds mbox: read sleep time 4500
[GOLF I] [STATE] IDLE->READY: std=0.002
[GOLF I] >>> State: IDLE → READY
[GOLF I] [STATE] Ready CONFIRMED: 201ms
[12825] D/sibles_utils mbox: delayCO5300_ReadID 0x331100
[12834] I/co5300 lcd_task: LCD module use CO5300 ICCO5300_ReadID 0x331100
[14653] I/co5300 lcd_task: LCD module use CO5300 IC[14659] I/drv.lcd lcd_task: Found lcd co5300 id:331100h
[14666] I/drv.lcd lcd_task: HW open done.
[14671] I/drv.lcd lcd_task: [OPENING] → [INITIALIZED]
[14677] I/drv.lcd lcd_task: open done.
[14683] I/drv.lcd_fb app_watc: drv_lcd_fb_init
[14689] I/drv.lcd_fb app_watc: drv_lcd_fb_init done.
[14708] I/TOUCH app_watc: Open
[14713] I/TOUCH tp_init: Find touch screen driver…
[14719] I/TOUCH tp_init: Probe 12028409
[14725] I/TOUCH tp_init: touch screen found driver 0x20037290, ft6146
[14733] I/TOUCH app_watc: Opened.
[14756] I/LVGL app_watc: [littlevgl2rtt] Welcome to the littlevgl2rtt lib.
[14784] D/APP.FWK app_watc: send msg[GUI_APP_MSG_RUN_APP] [Main] to gui_app_mbx tick:1518.
[14803] I/APP.FWK.INT app_watc: [Main]
[15057] I/drv.lcd lcd_task: Auto turn on display.
[15063] I/drv.lcd lcd_task: set brightness 50
[15069] I/drv.lcd lcd_task: display on
[15074] I/drv.lcd lcd_task: [INITIALIZED] → [ON]
[15086] I/drv.lcd lcd_task: set brightness 100
[15092] I/drv.lcd lcd_task: display on
[15097] D/APP.SCHE app_watc: ----------------app_schedule_task---------------start
[15106] I/APP.SCHE app_watc: >>Execute msg[GUI_APP_MSG_RUN_APP] tick:1518
[15115] I/APP.SCHE app_watc: app[Main] do LOAD, 20052f58
[15122] I/APP.FWK app_watc: finding Main in builtin apps…
[15129] D/APP.SCHE app_watc: app[Main] tgt_state [LAUNCHED] → [RUNNING]
[15137] I/APP.SCHE app_watc: app[Main] do START, 20052f58
[15143] I/APP.FWK.INT app_watc: [Main]
[15148] D/APP.FWK app_watc: send msg[GUI_APP_MSG_OPEN_PAGE] [0x20052f58] to gui_app_mbx tick:1557.
[15160] I/APP.SCHE app_watc: >>Execute msg[GUI_APP_MSG_OPEN_PAGE] tick:1557
[15168] D/APP.SCHE app_watc: app[Main] create page[root] 20053024
[15182] D/APP.SCHE app_watc: page[Main][root] tgt_state [CREATED] → [RESUMED]
[15191] D/APP.SCHE app_watc: Stop all app, and return to main app
[15202] I/APP.SCHE app_watc: page[Main][root] do ONSTART, 20053024
[15311] I/APP.SCHE app_watc: page[Main][root] do ONRESUME, 20053024
[15319] I/APP.SCHE app_watc: Try setup trans-anim
[15325] I/APP.SCHE app_watc: Trans-anim is OFF, skip.
[15332] D/APP.SCHE app_watc: app_schedule_task done.
[15539] E/drv.ft6146 tp_init: ft6146 id_H=64
[15546] E/drv.ft6146 tp_init: ft6146 id_L=56
[22389] D/bt_common mbox: dm_set init_gainst_data 565
[22396] D/bt_common mbox: svc_set init_gainst_data 606
[22405] D/bt_common mbox: [SPP_DEBUG]spp_uuid_header = 0x20058324,spp_uuid_list = 0x20058324,st = 0
[22416] D/bt_common mbox: hfp state change new_sate 0x 0,old_state 0x 0
[22432] D/bt_common mbox: AG state change new_sate 0x 0,old_state 0x 0
[22441] D/bt_common mbox: hid_init[22446] D/bt_common mbox: bt_gatt_update_state from 0x 0 to 0x 0
[22454] D/bt_common mbox: bt_dis_update_ctrl_state state 0x 0
[22461] D/bt_common mbox: bt_l2cap_profile_init######################################################
BTS2 Demo Main Menu
1. Generic Command
3. SPP Server
8. L2CAP bqb test
s. Show Menu
q. Exit
[22549] E/NO_TAG mbox: read bt bonded failed!
[22570] I/ble_cm mbox: read_bond_infor_from_flash: 1
le p256 nvds get 0
le p256 nvds get 0
app addr nvds get 1
[22702] I/sibles KE_EVT2:
BLE ready![22708] I/btcomm KE_EVT2: Clear mask 1
act num:0
set cmd 0x91, stop_status:0, msg_status:1
[22743] D/BLE_GAP KE_EVT2: evt 145, ret 0[27384] D/bt_common bts: dm_release gap_dm_sync_reg_cfm_hdl 885
[27400] D/bt_common bts: svc_release gap_dm_sync_reg_cfm_hdl 886
[27407] D/bt_common bts: dm_set gap_rd_local_version_req_hdl 186
[27415] D/bt_common bts: dm_release gap_rd_local_version_req_hdl 193
[27423] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27431] D/bt_common bts: dm_set gap_sm_set_default_sec_mode_req_hdl 430
[27439] D/bt_common bts: dm_release gap_sm_set_default_sec_mode_req_hdl 431
[27448] D/bt_common bts: dm_set gap_rd_bd_req_hdl 4774
[27456] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27463] D/bt_common bts: [spp_debug]inited_channel_num = 0,srv_chnl = 1
[27472] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27487] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27494] D/bt_common bts: [spp_debug]inited_channel_num = 1,srv_chnl = 2
[27502] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27511] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27518] D/bt_common bts: [spp_debug]inited_channel_num = 2,srv_chnl = 3
[27527] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27538] D/bt_common bts: dm_release gap_rd_bd_comp_hdl 4747
[27546] I/btapp_ge bts: << Local device addreess: 5CFD:52:800921[27555] D/bt_common bts: dm_set gap_sm_set_sec_mode_req_hdl 404
[27564] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27571] D/bt_common bts: [spp_debug]inited_channel_num = 3,srv_chnl = 4
[27586] D/bt_common bts: dm_release gap_dm_arrival_hdl 9447
[27593] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27741] D/bt_common bts: dm_release gap_sm_reg_req_hdl 649
[27750] D/bt_common bts: dm_set gap_rd_local_version_req_hdl 186
[27757] D/bt_common bts: dm_release gap_rd_local_version_req_hdl 193
[27766] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27780] D/bt_common bts: [spp_debug]inited_channel_num = 4,srv_chnl = 5
[27788] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27797] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27805] D/bt_common bts: hfp state change new_sate 0x 1,old_state 0x 0
[27813] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27821] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27828] D/bt_common bts: AG state change new_sate 0x 1,old_state 0x 0
[27837] D/bt_common bts: svc_set gap_l2c_reg_req_msg_send 774
[27845] D/bt_common bts: svc_release gap_l2c_reg_cfm_hdl 852
[27852] D/bt_common bts: svc_set gap_l2c_reg_req_msg_send 774
[27860] D/bt_common bts: svc_release gap_l2c_reg_cfm_hdl 852
[27874] D/bt_common bts: svc_set gap_l2c_reg_req_msg_send 774
[27882] D/bt_common bts: svc_release gap_l2c_reg_cfm_hdl 852
[27889] D/bt_common bts: hid_gap_l2ca_reg_cfm_standbyst[27896] D/bt_common bts: svc_set gap_l2c_reg_req_msg_send 774
[27903] D/bt_common bts: svc_release gap_l2c_reg_cfm_hdl 852
[27911] D/bt_common bts: svc_set gap_rfc_reg_req_msg_send 2622
[27919] D/bt_common bts: svc_release gap_rfc_reg_cfm_hdl 2726
[27927] D/bt_common bts: svc_release gap_app_init_req_hdl 76
[27934] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x20058324,spp_uuid_list = 0x2004f758,st = 0
[27945] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x20058324,spp_uuid_list = 0x2004f8e4,st = 0
[27957] D/bt_common bts: [spp_debug]The number of spp reaches the maximum
[27972] I/btapp_spps bts: >> SPP enabled[27981] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x20058324,st = 0
[27989] D/bt_common bts: [spp_debug]curr_list = 0x20058324,st = 0,srv_chl = 1
[28000] D/bt_common bts: dm_set gap_set_local_name_req_hdl 3767
[28008] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x20058324,st = 1[28018] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x2004f758,st = 0
[28027] D/bt_common bts: [spp_debug]curr_list = 0x2004f758,st = 0,srv_chl = 2
[28037] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x20058324,st = 1[28046] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x2004f758,st = 1
[28061] D/bt_common bts: [SPP_DEBUG]spp_uuid_header = 0x2004f8e4,st = 0
[28069] D/bt_common bts: [spp_debug]curr_list = 0x2004f8e4,st = 0,srv_chl = 3
[28078] D/bt_common bts: svc_set gap_sds_reg_req_hdl 2003
[28087] I/btapp_ge bts: << Write eir data success![28095] D/bt_common bts: svc_release gap_sds_reg_cfm_hdl 2078
[28102] D/bt_common bts: [spp_debug]spp_dump_uuid_list_node**
[28114] D/bt_common bts: [spp_debug]srv_chl = 1,st = 1,sds_rec_hdl = 0
[28122] D/bt_common bts: [spp_debug]0x11
[28127] D/bt_common bts: [spp_debug]0x1
[28131] D/bt_common bts: [spp_debug]srv_chl = 2,st = 1,sds_rec_hdl = 0
[28139] D/bt_common bts: [spp_debug]0x30
[28144] D/bt_common bts: [spp_debug]0x1
[28155] D/bt_common bts: [spp_debug]srv_chl = 3,st = 1,sds_rec_hdl = 0
[28163] D/bt_common bts: [spp_debug]0x30
[28167] D/bt_common bts: [spp_debug]0x2
[28172] D/bt_common bts: [spp_debug]********************************************
[28181] D/btapp_spps bts: spp enable success[28187] D/bt_common bts: svc_set gap_sds_reg_req_hdl 2003
[28195] D/bt_common bts: dm_release dm_hci_change_local_name_comp 3816
[28203] I/btapp_ge bts: << Local device name changed![28210] D/bt_common bts: svc_release gap_sds_reg_cfm_hdl 2078
[28217] D/bt_common bts: [spp_debug]spp_dump_uuid_list_node**
[28226] D/bt_common bts: [spp_debug]srv_chl = 1,st = 2,sds_rec_hdl = 10000
[28234] D/bt_common bts: [spp_debug]0x11
[28239] D/bt_common bts: [spp_debug]0x1
[28250] D/bt_common bts: [spp_debug]srv_chl = 2,st = 1,sds_rec_hdl = 0
[28258] D/bt_common bts: [spp_debug]0x30
[28262] D/bt_common bts: [spp_debug]0x1
[28267] D/bt_common bts: [spp_debug]srv_chl = 3,st = 1,sds_rec_hdl = 0
[28275] D/bt_common bts: [spp_debug]0x30
[28279] D/bt_common bts: [spp_debug]0x2
[28284] D/bt_common bts: [spp_debug]********************************************
[28293] D/btapp_spps bts: spp enable success[28299] D/bt_common bts: dm_set gap_wr_cod_req 7960
[28306] D/bt_common bts: svc_set gap_sds_reg_req_hdl 2003
[28314] D/bt_common bts: svc_release gap_sds_reg_cfm_hdl 2078
[28321] D/bt_common bts: [spp_debug]spp_dump_uuid_list_node**
[28330] D/bt_common bts: [spp_debug]srv_chl = 1,st = 2,sds_rec_hdl = 10000
[28338] D/bt_common bts: [spp_debug]0x11
[28349] D/bt_common bts: [spp_debug]0x1
[28354] D/bt_common bts: [spp_debug]srv_chl = 2,st = 2,sds_rec_hdl = 10001
[28362] D/bt_common bts: [spp_debug]0x30
[28367] D/bt_common bts: [spp_debug]0x1
[28371] D/bt_common bts: [spp_debug]srv_chl = 3,st = 1,sds_rec_hdl = 0
[28380] D/bt_common bts: [spp_debug]0x30
[28385] D/bt_common bts: [spp_debug]0x2
[28392] D/bt_common bts: [spp_debug]********************************************
[28401] D/btapp_spps bts: spp enable success[28407] D/bt_common bts: svc_set gap_rfc_acpt_conn_req_hdl 600
[28415] D/bt_common bts: svc_release connable_hdl 8151
[28421] D/bt_common bts: dm_release gap_rfc_profile_st_change_setting_ext 12368
[28431] D/bt_common bts: dm_release gap_wr_dev_cls_comp_hdl 8027
[28445] I/btapp_ge bts: << Class of device has been changed![28453] D/bt_common bts: svc_set gap_rfc_acpt_conn_req_hdl 600
[28460] D/bt_common bts: svc_release connable_hdl 8151
[28466] D/bt_common bts: dm_release gap_rfc_profile_st_change_setting_ext 12368
[28475] D/bt_common bts: dm_set gap_rd_local_version_req_hdl 186
[28483] D/bt_common bts: dm_release gap_rd_local_version_req_hdl 193
[28491] I/btapp_ge bts: << Local LMP version: 12[28496] I/btapp_ge bts: << Local LMP subversion: 591
[28503] I/btapp_ge bts: << Local controller manufacturer name id: 2636
[28511] D/bt_common bts: dm_set gap_rd_local_name_req_hdl 4706
[28519] D/bt_common bts: svc_set gap_rfc_acpt_conn_req_hdl 600
[28527] D/bt_common bts: svc_release connable_hdl 8151
[28539] D/bt_common bts: dm_release gap_rfc_profile_st_change_setting_ext 12368
[28549] D/bt_common bts: dm_release gap_sm_reg_req_hdl 649
[28556] D/bt_common bts: dm_release gap_sm_reg_req_hdl 649
[28564] D/bt_common bts: dm_set gap_rd_cod_req 8061
[28572] D/bt_common bts: dm_release gap_sm_reg_req_hdl 649
[28585] D/bt_common bts: dm_release gap_rd_local_name_comp_hdl 4678
[28594] I/NO_TAG bts: BTS2MU_GAP_RD_LOCAL_NAME_CFM
[28600] I/btcomm bts: Clear mask 2
[28604] I/btapp_ge bts: << Local device name: SifliDemo-21-9-80-52-fd-5c[28612] I/btapp_ge bts: service state 1
[28617] I/btapp_ge bts: bt stack ready[28621] D/bt_common bts: dm_set gap_wr_scan_enb_req_hdl 8717
[28653] D/bt_common bts: dm_release gap_rd_dev_cls_comp_hdl 8094
[28662] I/btapp_ge bts: << Class of device: 0x240704[28689] D/bt_common bts: dm_release gap_send_wr_scan_enb_comp_to_app 8643
[28699] D/bt_common bts: dm_release gap_wr_scan_enb_gap_comp_hdl 8549
[28707] I/btapp_ge bts: << Write scan enable success[28714] D/bt_common bts: dm_set gap_rd_scan_enb_req_hdl 8754
[28736] D/bt_common bts: dm_release gap_rd_scan_enb_comp_hdl 8675
[28745] I/btapp_ge bts: << Scan mode: 3[28750] I/btapp_ge bts: << Inquiry scan enbd.
<< Page scan enbd.
看log没什么问题呢,手机上是用什么搜索的呢,spp连接需要专门的串口传输软件才能搜索连接,手机上的话比如e调试,spp串口助手软件都可以,电脑上的话,可以用我们自带的sifliTrace软件可以看到会多一个串口,点连接就可以连上
