打印各个参数都对得上,就是渲染不出来,是不是要配置其他东西?
贴一下你的遮罩代码
static void test_rect_draw_event_cb(lv_event_t * e) {
lv_event_code_t code = lv_event_get_code(e);
lv_obj_t * obj = lv_event_get_target(e);
static int16_t mask_id = -1; // 保存遮罩ID(仅用于单实例测试)
if (code == LV_EVENT_DRAW_MAIN_BEGIN) {
lv_area_t coords;
lv_obj_get_coords(obj, &coords);
lv_coord_t cx = coords.x1 + lv_obj_get_width(obj) / 2;
lv_coord_t cy = coords.y1 + lv_obj_get_height(obj) / 2;
lv_coord_t radius = lv_obj_get_width(obj) / 2;
lv_area_t mask_area = {
.x1 = cx - radius,
.y1 = cy - radius,
.x2 = cx + radius,
.y2 = cy + radius
static lv_draw_mask_radius_param_t mask_radius;
lv_draw_mask_radius_init(&mask_radius, &mask_area, radius, false); // 修正半径参数
mask_id = lv_draw_mask_add(&mask_radius, NULL);
else if (code == LV_EVENT_DRAW_MAIN_END) {
if (mask_id >= 0) {
lv_draw_mask_remove_id(mask_id);
mask_id = -1;
void test_pure_color_mask(void) {
// 创建一个200x200的红色矩形
lv_obj_t * rect = lv_obj_create(lv_scr_act());
lv_obj_set_size(rect, 200, 200);
lv_obj_set_style_bg_color(rect, lv_color_hex(0xFF0000), 0);
lv_obj_set_style_radius(rect, 0, 0); // 确保无圆角
lv_obj_align(rect, LV_ALIGN_CENTER, 0, 0);
// 注册绘制事件
lv_obj_add_event_cb(rect, test_rect_draw_event_cb, LV_EVENT_DRAW_MAIN_BEGIN, NULL);
lv_obj_add_event_cb(rect, test_rect_draw_event_cb, LV_EVENT_DRAW_MAIN_END, NULL);
* @brief 页面运行
void ui_func_page_3_run(void)
static uint32_t start_time = 0;
if (lv_tick_get() - start_time > 10000)
start_time = 0xFFFFFFFF;
test_pure_color_mask();
我将你贴的代码放到lv8_example里面确实没显示,加上 lv_obj_set_style_bg_opa(rect, LV_OPA_COVER, 0);设置一下透明度就能正常显示了。
另外我这边提供一下我这边代码供给参考:
typedef struct {
lv_draw_mask_radius_param_t radius;
int16_t id;
} circle_mask_ctx_t;
static void test_rect_draw_event_cb(lv_event_t \* e)
lv_obj_t \* obj = lv_event_get_target(e);
circle_mask_ctx_t \* mask_ctx = lv_event_get_user_data(e);
if (code == LV_EVENT_COVER_CHECK)
lv_event_set_cover_res(e, LV_COVER_RES_MASKED);
else if (code == LV_EVENT_DRAW_MAIN_BEGIN)
lv_area_t coords;
lv_coord_t radius = LV_MIN(lv_area_get_width(&coords), lv_area_get_height(&coords)) / 2;
lv_draw_mask_radius_init(&mask_ctx->radius, &coords, radius, false);
mask_ctx->id = lv_draw_mask_add(&mask_ctx->radius, NULL);
if (mask_ctx->id != LV_MASK_ID_INV)
lv_draw_mask_remove_id(mask_ctx->id);
lv_draw_mask_free_param(&mask_ctx->radius);
mask_ctx->id = LV_MASK_ID_INV;
static circle_mask_ctx_t mask_ctx;
lv_obj_t \* rect = lv_obj_create(lv_scr_act());
lv_obj_set_style_border_width(rect, 0, 0);
lv_obj_set_style_outline_width(rect, 0, 0);
lv_obj_set_style_shadow_width(rect, 0, 0);
mask_ctx.id = LV_MASK_ID_INV;
lv_obj_add_event_cb(rect, test_rect_draw_event_cb, LV_EVENT_ALL, &mask_ctx);
