52开发板local_music例子死机
52开发板local_music例子,menuconfig增加了ulog,运行死机。
[2403] I/drv.rtc main: RTC use LXT RTC_CR=00000001
[2424] I/drv.rtc main: Init RTC, wake = 0
[2587] I/drv.audprc main: init 00 ADC_PATH_CFG0 0x606
[2609] I/drv.audprc main: HAL_AUDPRC_Init res 0
[2630] I/drv.audcodec main: HAL_AUDCODEC_Init res 0
[2651] I/TOUCH main: Regist touch screen driver, probe=0x12026ce1
call par CFG1(3313)
fc 9, xtal 2000, pll 2061
call par CFG1(3313)
fc 7, xtal 2000, pll 1649
Register root to mtd device with base addr 0x128a0000
mount fs on flash to root success
[LOCAL MUSIC]Local music Example.
Directory /:
16k.wav 601422
[LOCAL MUSIC]comm_init
[LOCAL MUSIC]play_file /16k.wav
[2953] I/audio audiosvr: audio server run
[2971] I/audio bt_downv: audio_btdownlink run
[LOCAL MUSIC]RECV msg: cmd 0
[3000] I/audio mp3_proc: mp3ctrl_open call by thread id=0x20014e2c name=mp3_proc
[3031] I/audio mp3_proc: mp3 open /16k.wav callback=0x12045a19
[3055] I/audio mp3_proc: mp3 open /16k.wav
[3086] I/audio mp3_proc: no ID3
[3104] I/audio mp3_proc: wav len=78
[3122] I/audio wave: wav run…ctrl=0x200156d0
[3142] I/audio mp3_proc: mp3ctrl_play h=0x200156d0
[3165] I/audio wave: audio_open type=4 d=253 rw=1 tx cache=8202 rx cache=0
[3196] I/audio audiosvr: audio cmd=0
[3211] I/audio audiosvr: audio_client_start h=20015860 n=music t=4 f=1 d=253
[3240] I/audio audiosvr: audio_device_open in d=0 busy=0 reg=1 c=0x20015860
[3268] I/audio audiosvr: device 0 info reg=1 busy=0:
[3288] I/audio audiosvr: device 0 info end
[3304] I/audio audiosvr: server first stream
[3321] I/audio audiosvr: device 0 first stream
[3339] I/audio audiosvr: device count tx=0 rx=0 busy=0
[3360] I/audio audiosvr: hardware_device_open in: r=0 t=0 b=0 d=0 c=0x0x20015860 f=1
[3393] I/audio audiosvr: audio_device_speaker_open in r=0 t=0 c=0x0x20015860 f=1
[3423] I/audio audiosvr: need init tx=1 rx=0
[3440] I/drv.audprc audiosvr: set g_eq_enable=1
[3459] I/audio audiosvr: (tx rx): ch[1,0] rate(44100 0)
[3483] I/audio audiosvr: config tx–set callback
[3503] I/audio audiosvr: prc_codec : sub_type=1 channel 1, samplerate 44100, bits 16
[3536] I/audio audiosvr: speaker OUTPUTSRC channel=1 in_rate=44100 out_rate=44100
[3568] I/audio audiosvr: speaker select=0x5050 mixer=0x5050
[3591] I/audio audiosvr: tx[0]: sub_type 0, ch 1, samrate 44100, bits 16
[3620] I/audio audiosvr: no eq init volume=-28
[3639] I/drv.audcodec audiosvr: dac set volume: prc=0 codec=-28
[3664] I/drv.audcodec audiosvr: codec dac mute set:1
[3685] I/audio audiosvr: speaker START stream=0x100
[3705] I/drv.audprc audiosvr: samplerate = 44100, select music eq
[3731] I/drv.audprc audiosvr: -----tx dma size = 1600
[3753] I/audio audiosvr: codec START stream=0x100
enable pll
new PLL_ENABLE vco:8, freq_type:3
pll lock! freq_type:3
[3877] I/drv.audcodec audiosvr: pll config state:2, samplerate:44100
[3910] I/audio mp3_proc: mp3ctrl_play ok
[LOCAL MUSIC]RECV END.
msh />[4238] I/audio audiosvr: open PA, unmute DAC
sifli_aw8155 to do power handle
sifli_aw8155_start,mode:1 10
local_music.zip|附件 (9.7 MB)
menuconfig中开启了Enable ISR log 吗?没开启的话可以开启一下
可以参考这个帖子
求助,配置按键pin引脚中断,出现类似卡死的现象 - 疑难解答 - SiFli BBS
谢谢,问题已解决。
